Teez-Nutz Dimensions
Hi, does anyone know the dimensions of the Teez-Nutz?
I want to try and find some t-track that will fit these to make a Shapeoko 4/Pro type waste board table layout on my Shapeoko 3 XXL.
Thanks,
Jeffery
Interestingly, the product page for those specifically warns against doing this. " Note: these are only compatible with the Shapeoko 4 and Shapeoko Pro Hybrid Table, they are not compatible with the T-Track table system for the Shapeoko 3." (from here: Teez-Nutz for Hybrid Table - Carbide 3D)
Although that is referencing the specific product here: T-Track and Clamp Kit for Shapeoko 3 - Carbide 3D
and it looks like the XL size is the only one in stock for that machine.
To actually answer your question, I measured the ones I received in my Get a Grip kit. They are listed in the package contents as Teez-Nutz, but they are square instead of having and oblong/oval shape. The body of them measures 9 mm high and 16 mm wide. That height does not include the threaded portion that sticks up to receive the bolt.
So, assuming what I have are the current version of the Teez-Nutz that are being sold (mine was purchased around Black Friday last year), that should be accurate dimensions. Or at least accurate to a millimeter using the ruler I have. I didn’t dig out the calipers to get that measurement.
Thanks Doug, I appreciate you taking the time to measure them.
I know their not compatible with the normal Shapeoko t-track but was hoping to maybe find something close but sounds like their track and nuts are a custom size. I haven’t found anything even close to that big of a slot.
Well on to plan B :smiley:
Thanks,
Jeffery
