Texture not respecting boundries in preview
(Andrew Doran) #1
Trying out some textures. I wanted to make an address sign with a hand-carved look. I got some decent looking hand carving grooves with a few adjustments of the texture parameters, but when I simulate the carve the texture lines protrude into the letter and outline that defines the space for the texture to carve.
Is this just a limitation of the software, or will the texture carve into the letters when I run it?
Here is the simulation with the texture off, and with it on.
(William Adams) #2
The problem is the textures are calculated at the center of the endmill — you can get around this by offsetting the text and insetting the boarder and then doing the texture for those paths instead.
(Andrew Doran) #3
I guess offset by 1/2 the dia. of the endmill is an OK workaround. I was expecting it to work like a pocket, and use the selected geometry as the boundary. I can’t think of a reason why you wouldn’t want it to work like a pocket, but then I probably have a bit of tunnel vision for my current needs.
Thanks for your reply!
(Andrew Doran) #4
Much Better, Thanks
My ball end mills arrive next week, so I can carve it!
(Rob Grzesek) #5
Be sure and post a picture of the finished part.
(Lake Forest, Ca. ) #6
Nicely done C3D. CC has come a long way since I tried it, hmmm, 3 years ago?
Think I’ll revisit. The latest version 400 looks good.
