I’ve looked through the archives, but can’t find an answer to my question.
I’m trying texture for the first time and it’s working out quite well. Is there a way to make the texture pattern follow a contour rather than a straight line? For example: If there were a snake like pattern (maybe a winding stream across a field), can the pattern be set to align with the stream as it meanders?
