The best doubleside tape for work holding ever!
Not affiliated with the company, I’m more and more impressed with the stuff every-time I’ve used it.
~18" of tape was applied on the underside of this stock.
SpecTape. Who needs a vice.
How hard was it to remove from the underside of the wood?
long enough of a fingernail and it comes off in one piece and doesn’t rip
I quit using a similar tape. It worked fine on thin stuff, because hardly anything else did. However, it left residue that wasn’t visible until I started sanding and finishing.
I still use it occasionally, but only on stuff where I’m going to take a layer off.
Haven’t had that issue least not that I’ve noticed. Just used it on a Plexiglas job and it didn’t leave anything once Pealed off,
What’s that one?..
@neilferreri
Might work better then the carpet tape I’ve been using. Then I have to clean the wood with paint thinner…so maybe I’ll give it a try
