When I start a job it should begin in the center and work it’s way around but instead it begins at the edge of the x axis and binds.
Please describe how you set zero for your machine and post your project file. You may have a mismatch of zero position definitions between the machine and the project.
I set zero the same way all the time, front left with the bit zero
Hampton Resurface.nc (37.2 KB)
This is just a resurfacing job BTW
Your path shows the zero at the left center
I did it at the front left corner, what am I doing wrong?
It actually did the same thing to me yesterday so I uninstalled both CB Motion and Create
Does your toolpath look like this?
If so, change the Toolpath Zero to Lower-Left (Design, Job Setup)
How in the heck did I miss that, thank you so much for your help. Its perfect now. You rock Tod!!
