so im making a pocket around a series of words and while there are definitely places where i need the 1/8" to do fine detail i would think it would be faster for the larger areas to use something larger like a 1/4".
is there an “easy” way to do the large area in on endmill and the detail in a smaller?
This is known as “Rest Machining” — Carbide Create doesn’t have support for this — you can manage it using offsets, or, use a V endmill and Advanced V carving and Pocket Clearing.
I have done that before and had good results. It is even easier with the bitsetter. I would mill out the entire pocket and lettering with a 1/4" bit, then step down to a bit that is no less than half the diameter of the previous one, so no smaller than a 1/8" bit, and then just do an outline of the letters (where you want that extra detail) as well as the pockets inside the letters. Then, if you still need more detail, you can do it again with a 1/16" bit.
I work at the smaller scale, so for me, It’s 1/8" → 1/16" → 1/32" bits to get the really sharp detail.
I use v-bits for some stuff, but I really like the straight wall pockets for some applications. So I just work my way down in size until I get to the detail I am happy with.
