Thread milling tests
I bought a thread milling cutter from Lakeshore Carbide and did some tests on a Nomad classic with Fusion 360 in reshape and aluminum. It worked out great, with some help I got on the Fusion forum.
Details about the CAM setup can be found here: https://forums.autodesk.com/t5/computer-aided-machining-cam/help-defining-thread-milling-tool/m-p/7141772
Thats pretty nice! Is that steel?
No, that is a piece of 1/8" thick aluminum I had around.
