Threading a Hole for a Screw/Bolt on a Nomad (Tapping/ThreadMilling)
Drill and tap (threadmill) sequence…
CAM is in the youtube description.
I’m pleasantly surprised that threadmills work this will in a Nomad. :smiley:
We don’t call this is a drill and tap - this is a drill and threadmill. They are distinct operations, each with advantages and disadvantages.
Tapping is MUCH FASTER than threadmilling… but one needs a unique tap for each direction, size, and thread count. Lots of holes - tapping is faster than threadmilling. Tapping can go into really deep holes but blind taps - not all the way through a hole - aren’t so nice. They cut through tough materials like butter.
Tapping requires very slow speeds - lower than what the Nomad can do.
Threadmilling is nice in that one needs a small number of tools - one? - to cover a wide range of hole sizes and directions. They are designed for use in high speed mills - 30K, 40K, 60K RPM - which is why I’m surprised this comes off well in a Nomad (and why I didn’t even mention them above).
mark
That was more for search-ability than correct nomenclature. Most people have heard of a tap and know what it does… I figured people new to cnc may not have heard of thread milling. (even Google thinks I always want to buy a new 3mm Treadmill… not!) :smile:
I have a different profile tool from Maritool that I’m going to try some M6 holes tonight. I’m a bit skeptical with regard to the rigidity of the Nomad, hence the reason why I took it really slow with the M3, but we’ll see.
cheers !
True, that is why I changed the name of the entire posting. :smile:
I’m very pleasantly surprised that threadmills work.
For those truly adventurous, they make threadmills that combine a threadmill (top) and end mill (bottom)! One can do the drilling, change spindle speed and program in the middle of the hole making, and threadmill! :grimacing: I’ve never had the courage to use such things and I don’t think the Nomad has a “Z” to make such devices very useful - the tools tend to be a bit long.
If you continue to have success, I will have to get some 0.125" shank threadmills and give it a try. BobCAD-CAM has all of the necessary support to do this kind of thing.
mark
You can even make external threads with a threadmill!
Yup… not that any of use will make screws or bolts or thread pipes… :joy:
mark
I’m hoping to use threading aaaaaalot. Haha. I’m glad this is all getting worked out now. Great job guys!
:v:
-Hank
Hey all.
Can you repost the video of the milling?
I actually just ordered a thread-cutting tool from Amana (for cutting threads in acrylic) and will try to make a point of recording a video of it.
