Should the eccentric nuts be tightened before tensioning the belts.
It seems like I’m too tight after upgrading to zplus and other belts.
If I now loosen the nuts wheel some wheels a spinning freely
Yes, make them tight enough you can barely spin them by hand before putting belts on, that way you can see that things move like they should and align properly before the belt tension muddles conclusions…
Follow the instructions here:
The eccentric nuts is a hot topic. See this thread and my comments at the bottom:
