To Peck or not to Peck?
While I enjoy the smell of burning wood I prefer it not on my CNC. I was using the drilling feature and as you can see below burned everything:
There are my settings:
The holes are 1/4" and I used a 1/4" bit. Any suggestions on the settings or the hole size so It won’t burn?
Thanks,
Joe
I always use Peck w/ Full Retract.
if I have to do a drill operation, but years of using a belt-drive Z-axis machine has me conditioned to avoid drilling unless absolutely necessary — usually I use a smaller tool and machine as a pocket.
When I last tried pecking, I found I didn’t have an end mill that would cut 100% of the bottom. There was always that dead spot in the middle that started the burn.
I like Will’s choice. I use a spiral path pocket to “drill” holes.
Is that maple?
I use flat bottom 1/4" holes between .25" and .5" deep to register parts to fixtures and to each other for glueup. I use similar feed and speed settings except with a 2 Flute compression bit.
I started with the #201 but also found it burns harder woods. Others feel free to tear by thought process apart here :slight_smile: I’ve truly had burning embers shoot up and out with #201 attempting to peck drilling. Its a 3 flute bit. Doesn’t seem it can eject chips fast enough. Others might be able to suggest altered feeds and speeds better than I could.
I get much better results with a 2 Flute compression bit.
I think @CrookedWoodTex is referring to Spiral pocketing in Vectric. It’s a great way to interpolate (big word I learned here) a larger hole with a smaller end mill quickly with no burning.
Start with a smaller hole ?
Full retract. I like the 2 flute idea
CNC machines are poor drill presses. The lowest rpm is too fast for a drill type action. Personally if I need a 1/4" hole I do a pocket with an 1/8" bit. It goes relatively fast and no burning. Those burn marks may show up later even after sanding. The wood got heated enough that it discolored. Likely discolored more than just the surface veneer. I also have a 3/16" router bit that could be used for 1/4" holes.
Well, I took a different approach. As @WillAdams suggested, I went with a pocket toolpath. However, I enlarged the hole by 1/16” and used a 1/4” up-cut bit. It worked well but as suggested the wood is permanently burned. This is now a test piece as I need to make a couple of changes to the design anyway.
Hole Milling
Contour Path, Inside/Left, I like to climb cut.
Best to use a mill between the R & D of the hole. Close to 3/4 D is good.
On the tool, set the Depth per pass to something deeper than the hole.
Set the Plunge Rage equal to the Feed Rate
Use Ramping to get about 1/4 - 1/10 of the tool dia per revolution.
This is a 1/4" hole, 0.750 deep, with a 1/8" tool. I’m shooting for 0.030",
so 0.750 / 0.030 = 25. I set the ramp angle to 4°, and got about 25 passes.
It will helical engage to the bottom, then make one planar pass & retract
Thanks Tod will give this a try. Thanks.
After some testing and input from this group, I’ve finally settled on the sweet spot for cutting these holes without burning:
Here are the settings I used:
A special thanks to @Tod1d. I took his input on settings and tweaked them a little.
