When running Carbide Motion ( in two different program versions ) the same thing happens. After probing the start location, the machine should go to the bit setter to fine its 0 to the top of the project. Instead it starts the spindle and the Z axes drops down to start cutting. The machine should return to locate its 0 to the bit then wait for a tool change. I can’t figure out if I’m forgetting something or not. I’ve had my Shapeoko 5 pro for over a year now. Any ideas.
