I have been having problems with the bit missing the tool measurer. My V bit catches the side so the depth is off by .1 or more inches. This results in the bit digging in too deep or barely touching the surface. What is wrong?
I have cleaned the sensors and tried manually adjusting the router.
In CM when you set up your machine it gives you the option to go to a preset location for the bitsetter. There are options on that screen to allow you to move to the place your button is. Save and continue.
@Zman is correct for newer versions. However if you are running older versions go to configuration and you can jog the machine to center over the BitSetter. I would encourage you to update to latest versions if you are running older versions.
