Tool not listed
Have cutter 251 listed in tool library picked for project. All looks good. I set up to cut go into probe n the cutter 251 is not listed to pick for the probe
Use a #201 — it’s the same dimensions, just different flute geometry.
Note that the #251 shouldn’t be used for metal or plastics — just wood and so forth.
That’s what I did used 201 n worked fine I only use wood for now. Thank you
