Tool Path - Time under 2 Minutes
[c:\users\user\desktop test2](http://c:\users\user\desktop test2)
I started using Pro Build 464. When creating the tool path it shows that time to generate is under 2 minutes. When I run the simulation it looks incorrect. Any ideas what to do to trouble shoot.
Thanks
John
Hey @John3, it looks like your file attachment failed, can you try and re-upload it ?
I tried uploading and receive this message
Sorry, the file you are trying to upload is too big (maximum size is 4096KB).
Compress it into a zip file and retry ?
Same message too Large
What size is your c2d file ? You must be using a very high-resolution image for you heightmap I guess ?
I changed the model resolution to standard. The file was originally 7420 mbytes. After the zip 5181 mbytes. The message too large sill coming up. when I tried to upload it
How large is the G-code file that you generated that showed up as “2min” for cut time ?
Difficult to tell what’s going on without having a look at the file though, to you have an alternate way to provide the file (put it on a Google drive or other file sharing site?)
How long does the toolpath calculation itself take ?
I wonder if CC chokes on the size of the input data.
Gcode Horse.nc (3.8 KB) It runs real quick now that I made the resolution standard. I attached the Gcode file. Maybe you can run it to see what I’m talking about. In the mean time I will look into another way of getting this file to you.
Yep so something wrong happened during toolpath generation, that G-code file does this:
There may be something wrong in the settings (depths/offset). Does the preview give a proper result ?
Mine looks pretty much the same. Zoom in on it. Weird huh. I can email you the file. Give me a address. Thanks
did you follow a setup similar to this
I sent the file you requested to
support <support@carbide3d.com.
Let me know if you need anything else. John
If you look at this in a new version you see that the stock isn’t thick enough:
Unfortunately, increasing the thickness too much crashes Carbide Create.
Please update to the current beta, then try re-creating the file with a stock thickness which matches the depth/height of the modeling which you do — let us know how that works out.
I am on 464 is there a newer version. If so provide me with link. Thanks John
Here:
https://carbide3d.com/carbidecreate/beta/
This topic was automatically closed after 31 days. New replies are no longer allowed.
