Tool pathing disappears
So I want two create pockets to partially hold marbles as part of a game board. I dutifully select each of the 100+ locations and pick the pocket tool path. Initially, the pockets all show up with the appropriate paths depicted…then as the last step when I click “OK”, all the tool paths depictions disappear and simulation shows none of them. What am I missing?
When you click on the toolpath to bring it up does it indicate that there are vectors selected. It usually tells you how many.
Is your bit too large to fit in the vector? If so nothing would show in the simulation.
I sure hope you group all those together so you don’t have to pick them multiple times.
