So I’m pretty new to designing with Fusion 360, and running into an odd issue: it looks like when loading generated g-code into CM, the design ends up being scaled. It’s not the hardware issue since CM itself shows toolpath extents scales about by the factor of 2. Looks at the g-code itself all coordinates appear correct though, and I don’t see any odd commands. What am I overlooking?
For example, the largest X command shows around 279mm, but CM shows (and tries to execute) as 550mm+:
1001.nc (3.1 KB)
vs
