I imported a dxf into CC and created a contour toolpath for use with the Mcetcher diamond drag tool. As you can see the blue lines representing the toolpath are not curved but straight lines. Is this normal or am I doing something wrong?
Many thanks in advance! Gunter
Zodiac inscription.c2d (164.6 KB) Inscription on zodiac medal.dxf (75.7 KB)
The Toolpath representation is optimized — the 3D preview should show things well (esp. if one has the high-resolution options enabled).
If need be, export to G-Code and preview in a 3rd party tool.
