I created a simple contour tool path to cut out an accurate inside circle on a segmented ring using CC version 530, but when the G code was loaded into CM, it caused the Z drive to just shudder and go nowhere. I had to pause and stop it. I loaded the file in CC version 526 and created the same toolpath, and G code and all worked well.
Please send that file and the generated G-code to support@carbide3d.com and we’ll do our best to look into it.
Done. Need 20 characters. Thanks.
