Toolpaths calculating
I have a project all ready to go and during the process of making tool paths i found one that will not stop calculating. I have unsuccessfully disabled and tried to delete. Issue being, the file will not save while this is still caculating. (756)
Can i resolve this?
Please try the new beta:
Will the current project be saved or that is going to be a loss?
Export to an SVG to preserve the geometry and take a screengrab of each toolpath so as to recreate.
The “Calculating” was an issue in earlier v7 beta software. They eventually solved it. If the tool path has a lot of vectors it can take some time to calculate. Very busy svg items can cause the problem. Make sure your objects are all closed vectors. In the earlier beta the “Calculating” kept showing but the file was saved anyway.
Dont know how but the new download opened and not a thing was lost. Then i tried deleting the problematic tool path and it deleted!!
Total success, no time lost and a new version of cc
Thank you so much!
