Hello I have a Carbide Create touch probe V1. Mother board went bad replaced it with a V 2.4. How do I install/hook up the touch probe V1 to it. I attempted to plug in where labeled but it brings up the new V 2 Touch Place.
The v1 and v2 Probes should be interchangeable in terms of connectors.
As I go to probe menu I have V2 Probe installed. How do install V1 Probe… I uninstalled Carbide Motion and reinstalled no luck any suggestions
It should be in the settings of Carbide Motion. There is a selection drop down.
In older versions you had to choose which probe you had every time you were probing… In the last couple of versions you can choose which one you have and are not prompted again.
