Im a little faster with gragh paper in laying out some designs. I understand the picture capture and tracing of a picture. Is there a method, after that, to clean up those lines so that they are not looking hand drawn? My current attempt is to trace the lines again with the line drawing feature. That way my lines are perfectly straight. Is there any magic ‘button’ i can press to automatically do this function? Or even a different way of achieving my same end goal?
My first cnc cut into wood is for my own business sign and although i dont mind flaws in it to look back on and see how far ive come, i also wouldnt mind my first sign being pretty slick too.
Thank you for your time.
If you go into Node Edit mode, one of the options is to convert a node into a “Sharp” mode, which will make that corner straight. See:
If you’ll post a scanned file, we can walk through this with you.
