Oh, so if there are gaps at the front right and back left, there’s no real need to sort it out?
How can I check the gantry is square to the Y rails?
Looks square on all sides. I did find a slightly loose v wheel on the X plate. After tightening it, the slop I had before disappeared. Will see if that makes any difference with the ridges.
The best way to check for square is to begin to tram your wasteboard or to mill a pocket out of as large a piece of scrap as will fit — once you’ve got a pass which goes all the way down along two legs of a corner use a known good square to check and see if they form a right angle.
