So I’m waiting on my new control board for my 5 pro 2x2 that I just got a week ago and i can’t get to run and even set up wizard had issues with many re tries and got it set only for it to go haywire even after i did get it set up, the laptop is more than capable to run the machine . The questions I have until the new board comes in is .
- what will the reset button thats on the control box do and would it possibly clear out the demons if that’s possible to try again a sample run
- is there any other steps I could go through.
The problems started with the machine jumping off the cutting area so I checked all areas to make sure the screws were tight that can cause the issue then test ran a 3 d program it worked but the next day machine went haywire cutting wrong and even wouldn’t go to the bitsetter correctly . To let you know this is my second machine I have a 4 xxl so this isnt my first rodeo. Thanks
