Here is copy of gcode in Motion
Machine: Shapeoko
GRBL Version: 1.1f
Carbide Motion 640
Machine Controller State: INIT
Grbl Cycle: Idle
“bitRunnerEnabled”: false,
“bitSetterEnabled”: false,
“bitSetterX”: 0.0,
“bitSetterY”: 0.0,
“bitZeroType”: 2,
“connection”: 1,
“lastConfigSent”: 0,
“lastProbeIndex”: 0,
“lastSizeOption”: 2,
“odometer”: [
“cleared”: true,
“minutes”: 1.7955666666666636,
“startDate”: “2024-09-18”,
“travelX”: 709.6000289916992,
“travelY”: 862.4499959945679,
“travelZ”: 261.15000146627426
“cleared”: true,
“minutes”: 7.880449999999986,
“startDate”: “2024-09-22”,
“travelX”: 4957.474536597729,
“travelY”: 9949.575128510594,
“travelZ”: 1212.1749997138977
“cleared”: false,
“minutes”: 0.4500666666666666,
“startDate”: “2024-09-25”,
“travelX”: 478.1499938964844,
“travelY”: 843.8500139713287,
“travelZ”: 36.874999046325684
“showCarbideRouterRpm”: true,
“spindleType”: 0,
“travelX”: -420.0,
“travelY”: -430.0,
“travelZ”: -100.0,
“version”: 0,
“webhooks”: ,
“workOffsetX”: 206.3000030517578,
“workOffsetY”: 161.4250030517578,
“workOffsetZ”: 13.149999618530273
0 = 10, Step pulse, microseconds
1 = 255, Step idle delay, milliseconds
2 = 0, Step port invert, mask
3 = 6, Direction port invert, mask
4 = 0, Step enable invert, boolean
5 = 0, Limit pins invert, boolean
6 = 0, Probe pin invert, boolean
10 = 255, Status report, mask
11 = 0.02, Junction deviation, millimeters
12 = 0.01, Arc tolerance, millimeters
13 = 0, Report inches, boolean
20 = 0, Soft limits, boolean
21 = 0, Hard limits, boolean
22 = 1, Homing cycle, boolean
23 = 0, Homing dir invert, mask
24 = 100, Homing feed, mm/min
25 = 2000, Homing seek, mm/min
26 = 25, Homing debounce, milliseconds
27 = 3, Homing pull-off, millimeters
30 = 24000, Max spindle speed, RPM
31 = 0, Min spindle speed, RPM
32 = 0, Laser mode, boolean
100 = 40, X steps/mm
101 = 40, Y steps/mm
102 = 40, Z steps/mm
110 = 10000, X Max rate, mm/min
111 = 10000, Y Max rate, mm/min
112 = 5000, Z Max rate, mm/min
120 = 500, X Acceleration, mm/sec^2
121 = 500, Y Acceleration, mm/sec^2
122 = 400, Z Acceleration, mm/sec^2
130 = 845, X Max travel, millimeters
131 = 850, Y Max travel, millimeters
132 = 100, Z Max travel, millimeters
Maintenance:
Travel (km) 0.00, 0.00, 0.00, 0.01 Hours since 2024-09-25
Travel (km) 0.00, 0.01, 0.00, 0.13 Hours since 2024-09-22
Travel (km) 0.00, 0.00, 0.00, 0.03 Hours since 2024-09-18
Queue Empty
