Trouble with modeling
I am trying to do a raised image CNC. The simulation in 3d modeling looks good then when it is ran with tool path’s it comes out weird. Using a 1/4 inch 201 for 3d roughing and 1/8 102 for final 3d. I am new to modeling 3d and have switched out final 3d bit for others and still have an issue. I have done test with simple bowl 3d modeling with just a circle and the tool paths come out fine. I am wondering if I am doing something wrong working with the clip art. Thank you
Please upload the file.
It looks as if you have limited the area for the toolpaths to only that of the 3D model — if you want the 3D part cut out then you will need to offset to the outside to allow that, see:
Or, you can add an additional Cutout toolpath:
upload cat.c2d (180 KB)
I am not trying to cut the cat face out. I am trying to make the cat face come out of the wood. It looks ok from the simulation in the modeling page but when I add tooling things go wrong. I know it is user error but can’t figure it out. I re watched both videos. thank you
You have the arch described as the Stock:
There are two different ways to approach this using 3D:
  • model the stock in its entirety and then cut the entire area as a 3D model
  • cut only the 3D portion as a 3D model and then cut the balance with a 2.5D toolpath which matches the depth
Also, if you are modeling only flat surfaces, then arguably this could be done using 2.5D toolpaths — we will cover all of these here.
First, to model the stock in its entirety:
We note that the stock is modeled to a thickness of 0.2 inches:
So we draw geometry the entire area:
Disable the original stock:
Then model the stock using the new geometry:
Apply
Show 3D
If we then transfer the existing 3D toolpaths to this new geometry we get:
which previews as:
Alternately, we select the geometry which defines the raised area which we wish to be left after the balance of the stock is removed:
and use it for the 3D toolpaths:
H
which previews as:
We then draw in geometry which defines the edges of the stock:
Add Dogbones to ensure that the corners are cut fully:
and adjust the radius:
Selecting that geometry and that used for the 3D toolpaths by shift-clicking on the latter:
We then assign a 2.5 toolpath to remove the balance of the material:
OK
which previews as:
The last option is to simply cut each feature using 2.5D toolpaths.
Select the elements which describe the highest point, then add the surrounding geometry:
and cut as a 2.5D toolpath — but note that the narrowest region:
will determine what size tool must be used to cut that feature.
Since you have Pro we will use REST machining so that it is not necessary to cut out the entire surface with a small tool.
Pocket
Ok
Checking the 3D preview we see that a bit is left uncut:
We then add a second Pocket toolpath:
and enable Rest machining and choose a suitably small tool
(duplicating the previous and editing it is arguably the best option)
Ok
Checking the 3D preview:
Shows that the whiskers are cut neatly and compleatly.
Iterate down with each remaining feature, so the eyes and mouth and nose and ears
Note that the toolpath may begin at the bottom of the preceding one so as to not have “air cutting”
Ok
Then select the face and the stock geometry:
and assign a pocket to cut out the face:
which previews as:
If desired, a REST Machining pass may be done here as well.
Then we remove the balance of the material for the other outline:
I would suggest adding the various begin/end depths to the toolpath names so as to help keep track.
If none of those are what you want, please make a rough sketch and we will do our best to get on the same page.
WOW Thank you! I will read all this slowly and try it out ASAP. THANK you soo much.
Some times you try and make things harder then they need to be. Thank you William for setting me straight. A few Christmas presents done.
