Trying to cut down on project time, need help!
Hey there, I am working on a project for my church and need some ideas. I am making communion trays that look like cutting boards with 40 holes drilled in it. I am trying to cut down on job time, but not quite sure how. I am new to CNCs so I am not really confident with my xxl yet. I am cutting out 40 holes in 3/4" walnut. The holes have a 1 inch diameter. I tried doing just an inside offset with a tab, but the waste just went flying anyway. Carving out pockets for all 40 holes with a .201 is almost an hour cut time. are there larger end mills or drilling mills that could be used to accomplish this?
Any ideas?
BTW I have the carbide router.
Seems like you might have some very conservative speeds and feeds. What is your depth of cut and feedrate?
Walnut is relatively soft so you can get a little more aggressive.
You could: increase depth per pass from the default 0.04" to 0.08" (still ok with a #201 in walnut), and feedrate from 60ipm to 80ipm (with #201, at 18000RPM that’s a chipload of 0.0015", still OK)
and use tabs (say 2 per hole) to hold the inner parts, that would cut the 40 holes in 18 minutes:
BUT then…cleaning up the tabs in 40 holes would probably take you almost as long as cutting the holes as pockets…
EDIT: the fundamental issue is that CC is not great at cutting small pockets, because of its retract policy. It will spend half the time retracting the cutter in the air…
spindle speed - 19700
feed rate 65
plunge 32
depth per pass .1
Which z-axis do you have? Might be possible to speed things up. And the thought of cleaning up 40-80 tabs over extended time to pocket… afters years and years of hand sanding, I will happily wait on the machine.
I have the belt drive Z axis, I’m not too keen on 80 tabs either lol.
Well actually I hate tabs too for that very reason, and last time I used them is about two years ago, this was just to address your point of waste flying away (I assumed your were using clamps). If it were me, I would use tape & glue workholding (as I always do), do inside contour cuts and no tabs, and that would probably work just fine. What I would do is choose the depth per pass such that the final pass is only cutting a very thin layer of material (removing the onion skin), hence very little forces, hence the tape would keep the waste in place easily, 1" is large enough of a diameter.
I would target a last pass of 0.02", so depth per pass of 0.73 / 7 = 0.104".
