Trying to limit X and Y travel range
I don’t these GRBL values are used for anything in C3D machines. I think they are for ‘Soft Limits’ when that is enabled.
To limit the travel, you need to edit the settings file for CM. It used to be a setting, but C3D in their infinite wisdom removed it from the UI.
