Okay, so my XXL is all assembled and all seems to be working flawlessly . Still waiting on my suck-it thoughā¦
I drilled out 288 holes for hold down anchor points with the E-Z Locks. I also made a set of clamps (Yea!!!) not perfect but they will work. Seems like the depth was off a tadā¦
So now Iām attempting to V Carve but want to make sure I have the correct specifics in the tool settings.
Iāve bought all my bits from the Carbide store and Iām adding a 60 V Cutter. On the case the bits arrives in, does it have the specific info I need to enter into the tool settings?
I know this⦠Type, Description, Tool #, Angle and Number of Flutes. Where will I find the rest of the information I need to set this tool up correctly? Iām specifically looking for ādiameterā and āflute lengthā.
Thanks for reading⦠I did try the search option but could not find my specific answer.
The listings pages on shop.carbide3d.com have the specifications for the endmills ā unfortunately, itās not aligned with what is used in Carbide Create (or MeshCAM?)
Note that Carbide Create uses taper angle, not the typically reported V-angle, so one must divide by 2, so the 90 degree bit is reported as having a 45 degree taper.
it would be nice if there would be a block of text on the product listing page which would copy the information and paste it into Carbide Create ā probably the next Carbide Create update will add support for the missing endmills.
FWIW, I suggested an integrated system where Carbide Create, Carbide Motion, and the shop on the website would all work together seamlessly so as to function as a machinistās log, tracking machine time, which cutters were used for what projects, estimating linear inches of travel for endmills, &c., but no interest.
