Unclosed vectors carbide create
I am not sure what I am doing wrong here, and I dont know how to fix it.
I imported a flag using the trace image tool to get a vector, and It traced right, but I couldnt get the sizes correct, so I exported SVG, imported into fusion 360, got the size correct, exported as dxf, tried to bring it into carbide create and have unclosed vectors.
I cannot figure out how to use the join tool to fix it or any other tool, including deleting and redrawing lines, in carbide create, so I’ve gone back into fusion 360 and drew each and every line so they are connected in f360, ive deleted all the lines and made sure they’re not over top of each other (i dont know if fusion has a overkill command like autocad does)
What am I missing or how can I use the tools I have to make it so I can cut this?
The fundamental rule about joining vectors is “You cannot join to a closed vector”.
Every vector that you select to join must be open - i.e., colored magenta when not selected.
Screenshots are almost useless, post your C2D file.
Heres the file
flagtest.c2d (96 KB)
OK, your stripes are slightly different widths, alternating. Is that what you want, or are all the stripes supposed to be the same width?
Regardless, rather than joining vectors, I would just delete them and then copy-paste the rectangles you already have, or draw new ones going node-to-node.
flagtest.c2d (104 KB)
Well ideally they’d be the same but it doesn’t matter as long as they’re visually the same
I just wanted to engrave it in colorcore, as a test
But what actually is going wrong, I’m not understanding?
On the second to bottom ‘rectangle’ - all you have is the unclosed vectors at each end of the rectangle. There’s nothing to join, because you haven’t defined the long edges of the rectangle.
The other rectangle on each side don’t help here - the vectors in those rectangles can’t be used since they are already closed.
Here’s another screenshot after I deleted all the already closed vectors that you can’t join with:
There’s not enough there to be joining, there are no vectors that together define a closed space.
Since it’s all just simple rectangles, I just drew new rectangles. The edges of the rectangles can overlay each other, what you want to avoid is having the internal areas of the rectangles overlapping.
This is probably most easily re-drawn:
First make a new layer:
and make it active and red:
and turn off Snap to Grid:
and draw in the red stripes:
until one arrives at:
Then make a layer for white (we will use light grey) and repeat:
and repeat for blue:
Delete all extraneous elements.
Attached as a v8 file:
flagtest_v8.c2d (96 KB)
Or, see:
Long story short, maybe it’s possible tracing it, exporting it, and trying to fix it in fusion 360 compounded an issue?
I’m still reading through what you wrote, and thank you for taking the time
Thank you, I think conFusion 360 did it weird, I’m going to try redrawing from scratch in AutoCAD, but I’m also going to work through and try to understand how to fix this
Anyway, I don’t know if this is the proper way to give credit, but the two of you that replied tonight helped me a lot, I ended up redrawing it inside carbide create using layers
This is what came out
Our pleasure! Glad it workd!
Credit is done by using the “Solution” checkbox:
