Uneven Z depths after cutting good ones
I have cut several baseball dice games and they went well until tonight. In attached photo I have marked 3 areas that the depth is uneven. I start with 0.025" then I make another cut at 0.027" to clean up the cuts. The 3 areas I have modified the depth of cut several times and at present, I’m at 0.115" and they won’t clean up. I have rezeroed the Z axis, but not the X or Y. Does someone have any hints as to what I might try? I tried to load the Carbide Create file, but I get a message that it is too large.
Your spoil board looks good. I have to ask, when was the last time you leveled it?
Looking at the project, it looks like it is in the lower middle. Could it be warped? The O and U look to have been affected also.
Ensure your bit is tight in the collet. I ran into a similar issue cutting aluminum and my bit was not tight enough. Everytime I lowered Z, the bit just slid farther into the collet. It was very odd until I found the problem.
Cheers.
I made one of those as one of my first projects. Mine was on a bamboo cutting board. I made a few bad design choices leading to some messed up lines in a spot plus it is hard to read just in the grain.
I like the contrast you have. Did you paint or is that some other
Zman, This is a new machine that has been in service less than a month. Could the stock be warped, yes. I have put a straight across it several directions and I don’t see much deviation with the naked eye. I would have thought that changing the depth of cut as much as I did, I would have seen some improvement. I just redownloaded both create and motion, maybe I had a hick up somewhere. Also, going to check the tightness of the collet, per Bozo’s suggestion.
It is painted. What bit did you use for the peg holes? I have tapered bit that I’m going to try on this board after I get my other issue resolved.
I would recommend using a more acute tool — I have defined a 30 degree Amana as:
and it has less vertical variation for horizontal, so is more forgiving of an uneven surface.
Thanks, another tool that will have to try.
I will check the file when I get to the computer later.
Is the stock itself flat? Is it possible that you’re not seeing any change because you’re at the limit of z travel in the downward direction? Usually if I am carving intricate details I will take a pass across the entire board to ensure it’s flat to the machine because I don’t have a planer. The fact that you moved the zero .080” or so and haven’t cut those areas make me think it’s a combination of those two things. There could be small dips there and if you’re at the limit of travel it’ll lose steps at the very bottom.
I’m rather certain that it is relatively flat, but not 100%. The notion that you bring up about the Z depth has reached its limit is a great suggestion. I guess that when it set the depth with the bitsetter, I would be good to go, maybe not though. When I recheck the collet for tightness, I will move the cutter some and then rezero the Z depth. Thanks shapeokonoob.
I checked the file. I used a #102 1/8" bit for the holes and went .4" deep.
My stock was .6" thick.
I used that bit for the holes and the dice pocket.
For everything else I used the same bit as @WillAdams suggests the Amana 45771-K 30 degree.
Thanks for the feedback.
Well, it turns out that my stock was not flat. After extending the cutter and other things I started to cut again. Right out of the gate I was seeing the same results. So I removed it, planed it and ran it through my drum sander. I started all over and what do I find, the cuts were being made. So slap me silly, take more care when starting a new project. Also, I want to thank everyone for trying to resolve the issue. Your input is greatly appreciated. Happy cutting my friends.
Don’t say that too loud, Last time I had a line of people ready to slap.
Good Luck.
Make Chips not dust
