Griff
(Well crap, my hypometric precursor device is blown…)
1
Appreciate if someone could look at these cut files and tell me what sort of gremlin I’m chasing, machine or GRBL. Both work fine in simulation. coaster cavity contour.nc (2.2 KB)
At the end the spindle plunges instead of lifting…you can imagine the results. Same thing happens with a 2d adaptive for the same part, at the end of cut the spindle plunges and plows back to the start point. (HDZ and spindle don’t miss a beat, haha. Y strains a bit but soldiers on until I hit estop.) coaster holder 2d adaptive.nc (293.2 KB)
I’ve made a few other test designs with similar parameters, work fine in simulation and as aircuts.
Not reversed. The command at the end sends the Z to “5” below the Z limit switch. When you’re in mm mode, 5mm makes sense. Five inches below your limit switch usually isn’t where you want the Z to go.
New version checks unit.
If MM, go 5mm below limit switch
Else (inches), go two tenths below limit switch.
Griff
5
