Updating Carbide Motion Issues
Tried to update to the newer version (6) of Carbide Motion. Machine was working PERFECTLY on the ver. 3 of Carbide Motion, but thought the update would be beneficial.
Was greeted with this during setup:
“There was an error during the homing process.
GRBL Alarm 9
Homing Failed. Could not find limit switch within search distances”.
Anyone else having this “failure”?
Thanks in advance for any help…
Power on and connect but do not initialize. Do a machine setup. It is possible that the new version of CM does not know what kind of machine you have.
Right at the bottom is “Setup New Machine” If you still have problems after setting up the machine than come back here or go to support.
