User defined tool parameters
I’m trying to add a new tool into the tool database, because I needed a tool variant that Carbide don’t sell.
I made a new User Library and added the new bit. The “flute length” and “num flutes” fields were filled out automatically, but there does not seem to be any way that I can alter those fields from those defaults.
I get that those fields are probably just “for information” and don’t provide any information that feeds into the toolpath software, but it would be nice if the stored information could be made correct.
How can I set those values?
You can open CC and in the Help menu click on About. Then you can click on “Open Data Directory”. Open the Carbide Create Folder. Then the Tools Folder. You will find your new library you created. Double Click and the library will open in a spreadsheet application. Edit your tools as you wish and save back in the CSV file format in the location you opened it from.
Here is an fly cutter tool database I got made for reference.
number vendor model URL name type diameter cornerradius flutelength shaftdiameter angle numflutes stickout coating metric notes machine material plungerate feedrate rpm depth cutpower finishallowance 3dstepover 3dfeedrate 3drpm
601 whiteside 6210 Fly Cutter end 1 0.125 0.25 0.25 2 3 0.25 0 Shapeoko MDF 10 80 16000 0.01 1 20 80 16000
602 Sugelary X002JUT7TF Fly Cutter end 1 0.125 0.25 0.25 2 3 0.25 0 Shapeoko MDF 10 100 16000 0.01 1 20 80 16000
503 Carbide3d MC Etcher MC Etcher - Diamond Drag Bit - Carbide 3D 90d Vee vee 0.25 0.25 90 0 0.25 0 Shapeoko MDF 30 200 1 0.1 1 0 200 1
Carbide3d MC Etcher MC Etcher - Diamond Drag Bit - Carbide 3D 120d Vee vee 0.25 0.25 120 0 0.25 0 Shapeoko MDF 30 200 1 0.1 1 0 200 1
