I was lazy and got hold of a vetric file and thought I could easily use it in CC.Unfortunately I am stumped.Is it possible make use of these files??I am on apple and Pro.
You would need to create an SVG or other compatible format out of it and then import into CC.
If it wasn’t a purchased file you can send it directly to me and I can convert it for you.
Hi Cullen,it was purchased for a small amount,if you would not mind doing it I would appreciate it.I have it on My Mac so I will get it over and send it.May be a good hour away as I need to go and feed the Llamas!!
