Have you exceeded the cutting diameter of your vbit? You don’t mention the vbit angle, but I can imagine something like that if you are deeper than the depth of cut on the bit
When using Advanced V carve it is necessary to keep the cut w/in the limits of what the V tool can cut at the end of multiple passes w/o running out of flute length.
Or you create some extra paths to remove the remaining material.
Offsetting the vector & following it with the V tool at appropriate depths.
If it’s a 1/2" dia 90° Vee, the flute length is 0.25", so if you offset the edge 0.2" & cut a depth of 0.2", then offset 0.4" and cut 0.4" deep, it will clean up those edges.
