Using advanced V carve
When using advanced V carve in 3/4” materials, using a 60 degree V bit do I have to set depth of cut or does the program do it automatically
The program will set the default depth of cut from the tool library. If you want to change it, you can after you select the tool. If you are using the clearance tool, you will need to set depth of cut on that tool as well.
