Hi All-
I’m using a popular guide <tinyurl.com/y7s4dbhg> to calibrate X and Y dimensions on my Classic Nomad 883. As the guide is not Nomad specific I’m also following the Carbide Motion FAQ on ‘default GRBL settings’ <tinyurl.com/yajgwkgf>. In step 5 of this guide it says ‘From the info pane, you can load the default Values by pressing ⌘+1 (ctl+1 on windows). You will see the values begin to scroll through the log on the right’. The accompanying image shows that this instruction refers to an earlier version of Carbide Motion. In the current version of this software (v. 4.0.416) this does not work.
Grateful if anyone could explain to me how to find the current X and Y (at $100 and $101, respectively using the latest version of Carbide Motion
Stay Safe and Black Lives Matters!
-Peter
