I am new at this and in carbide motion, I have my depth set to .065 but find this is still to deep, I go back to create and change depth setting and save download file into carbide motion, however the depth is still the same. What am I not doing to change the depth setting? I want the depth to be just a very thin line
Thanks
If you create a regular vcarve toolpath it will cut as deep as it can to meet the sides of the selected vectors. If you need to limit the depth, you need to use an advanced vcarve toolpath. If you just need to engrave a shallow v grove along a given line/vector, use a contour toolpath. It may not preview correctly but will cut fine
Thanks for your quick response.
