New to this hobby. Great joy at printing the logo after assembling my V3. Couldn’t wait to get the waste board (with inserts) started.
Well, the mess. Unbelievable! had to stop part way through the job. Have now got setup with vacuum and should be better. But how to get started again? All the holes in the grid are started; some deeper than others.
Your help appreciated Thanks
Zero is persistent, so you should be able to just re-run your file, removing the already made holes first.
Alternately, you could re-make your baseplate using the original as a template, then repurpose the original as a threaded insert board.
