VBit Depth Error
I am having an issue with Vbit depth. The left half of my project came out at the right depth but the right half is not even close. I don’t understand what I’m doing wrong.
Also if I try to rerun just the right side, it says estimated time 42 minutes in create but then when I bring it over to motion it says 19 minutes?
4H Backside Barrow and Gilt.c2d (2.7 MB)
Your stock is most likely not the same height. Surface the stock with the machine to get it all at the same Z height. Use that as your Z zero.
It says 14 minutes in the file.
can’t agree more with Todd: even stock is needed.
But also don’t forget how important it is to level the work area. Of course if the stock thickness is not of concern just level the stock urfacing it: that equalizes the level of the stock with the level of the machine, and the carving has always the right depth relatively to the stock surface. In you case with two separately appearing boards leveling the stock might probably solve this issue.
Thank you so much for your help!
