Vbit speeds in Dibond/Aluminum composite?
Does anyone have a good feed/speed/DoC for running Vbits in Dibond or other similar aluminum composites? It seems that no matter what I try, I can’t get a cut free of chatter marks in it…
Tried and tested settings for a .250 60 degree Vbit and a single flute 30 degree engraving bit would be greatly appreciated.
For a really clean edge, you should run 2 ops. Use the offset feature to create the first, leaving a couple thou for the second op.
-Edward
