hello. can the bitsetter be used with Vcarve, i.e. run 1 Gcode for multiple toolpaths? thanks
Yes, search for it or wait for @neilferreri to give the details. You install a different post-processor (PP) that understands the change bit gcode.
I did it recently, and neil’s PP works without a problem.
thank you for the information. I see 4 options: Grbl in/mm and Shapeoko in/mm. Which one is correct to replace carbide motion?
Yes. That’s exactly what I use. Here’s the how to.
I see. this does not replace carbide motion, only makes changes to how v carve writes the g code. I would not have understood how to do this without the video. thank you so much.
This topic was automatically closed after 34 days. New replies are no longer allowed.
