VCarve pro with a laser module issue
Hi all
Having a problem with firing up my add on JTech Photonic 7 watt laser in auto mode. I am trying to use the machne to complete a hybrid project, but my laser will not fire up in auto, it will fire up in full power and will follow the tool path saved to a gcode tool path, any surggestions as to the issue
Check to be sure the connections between the Shapeoko and laser driver are correct and the mode switch on the driver is in the correct position. If you’re good there get in contact with JTech. They are always very helpful.
