Vectric Aspire >> PP Shapeoko (inch) TOOLCHANGE >> Cutting To Deep
I can’t seem to figure this out, if I’m doing something wrong.
I have a piece of wood, let’s say 0.495in thick. In Vectric Aspire, I set the material thickness to 0.5" and the material surface as zero.
I use a 0.25" compression bit, Amana. The bit is in the Vectric Amana tool database and auto-selects a lot of parameters. Aspire sets 2 passes, 0.25" each pass. Great!
I save the tool path using the Shapeoko inch toolchange pp.
I open in carbide motion. I have the bit setter and the touch probe, but for this to keep it simple I only use the bit setter. I’ve had the same issue using the touch probe.
Initialize, then I jog the bit to exactly where I want the zero, and z it down until there’s no light below the bit on the surface. I zero all.
I add the tool path, start, it probes again, asks me to turn on the router, and begins.
It pushes very deep into the wood, well over 0.25", probably 80% through the material depth and moves along as the bit screeches.
Am I doing something wrong here? Very simple cuts, but wasting a lot of material.chipssides.gcode.zip (456 Bytes)
Well the g-code looks correct and consistent with the depths you mentioned
G17
G20 => units is inches
G90
M6 T1 => tool change pop-up + bitsetter probing
S18000M3 => spindle on pop-up
G0Z0.8000 => move to the retract height of 0.8"
G0X0.0000Y0.0000
G0X0.2836Y0.3746Z0.2000
G1Z-0.2500F20.0 => plunge to -0.25" (depth of the first pass)
G2X0.1603Y0.5201I0.0000J0.1250F40.0 => start moving in the X/Y plane
[etc…]
So probably the mechanical Z reference is wrong/lost somewhere
  • either something happens during the zeroing
    • does Z read 0.00 after you zero all & clear offsets ?
  • or the Z reference is lost after zeroing. This can happen if the Z axis reaches its top limit upon retract.
    • When you are at the point where you have jogged the bit to the surface and are setting Z0, how much travel is there left on the Z axis between the top of the Z plate and the limit switch?
Does it happen if you disable BitSetter in the settings (you don’t need it for this particular job anyway)?
Zeroing in (pun intended) on what Julien says, check your retract height setting in Aspire. Its in the material setup, I think.
You could be retracting the router beyond the upper space left to move.
A retract height of 0.8" is pretty high. I usually use 0.2" or 0.1".
Yes, it reads 0,0,0.
There is plenty of space. Above the base is a 1” mdf spoil board and then the material at nearly .5”.
What kind of Z axis to you have on your machine (stock/Z-plus/HDZ) ?
I would
a) double-check that if you jog 1inch on Z, the axis actually moves by 1 inch
b) retry the cut (possibly as an air job if you don’t want to waste material) with the BitSetter disabled
