Vectric + Bitsetter
I tried Bitsetter with SO 5 Pro and Vectric Pro but did not have much success. So I just removed the Bitsetter and disabled it in CM.
Only recently was it found that the issue in Vectric PP.
Found reference to this https://github.com/neilferreri/V-Carve-PPs.
Is anyone using it with SO 5 Pro and the latest CM?
Also, if in use, do I need to press the “Load new tool” button in the Run section?
When saving toolpaths, can I combine them or do I need to use them separately?
I appreciate the detailed step-by-step instructions on this because I am tired of bad attempts and ruined pieces and could not catch the right approach. Probably just me :slight_smile:
Thanks a lot!
