I recently purchased the Shapeoko 5 Pro and I finally got everything put together but I have a couple of problems. Whenever I turn on the machine, the VFR spindle starts right away. I’ve tried to send the MDI “M5” code but nothing happens. The only way I can stop the spindle is pressing the stop (reset) on the VFR box. Secondly, when I try to use the bitsetter, the machine keeps trying to push down into the bitsetter, and I have to kill the power. The red light is always on the bitsetter, and when I push down on it, the green one lights up.
Yes, I went through the set up again and made sure the spindle was set up as VFD spindle and the spindle still starts shortly after turning the power on.
