My shapeoko 3 xxl vibrates when moving along the x axis during homing. The switches and drag chain don’t seem to be in the way. I believe it has to do with the belt. Can someone help me resolve this issue?
It’s like the belts teeth don’t sit right on the pulley system. And when I manually move the x/z assembly freely the vibration kicks in and clearly doesn’t seem right.
Can you post a video?
Pic of this?
Can you see this videos I am sending?
https://share.icloud.com/photos/079CSvFI5XRVW3J2U_J98hE2Q#Palm_Bay,_FL
Can you see the videos I am sending? @neilferreri
Yup. It’s hard to tell in the manual movement one? Does the same thing happen if you move slower?
In the homing video, it looks good until your Y axis hits its physical limit without stopping. The issue there would be your Y limit switch.
Does the Y axis switch get pressed? Check your wiring there.
