I mailed them about their threaded table and whether it needed to be faced after installation.
The reply was ‘no’ but I was curious because AIUI the factory table is faced to ensure it is true.
So I decided I wanted to stick with the default Nomad table (so I can use C3D vise and flip-jig)
and did this instead:
The fixed adapter is located in one of two positions using dowel pins into the original nomad
table and then the reference surface has the final cut made to ensure it is parallel to X.
My original plan was to be able to accomodate two SMW jaws per adapter until I realised that the
left hand bolt slide on the movable adapter would foul the main jaw bolt.
