I glued up a 16" X 16" X 1 1/2" thick for my latest carve and alternated the end with one grain going up and the next going down. Each piece is 2 1/2" wide. In regular woodworking, I have done this my entire life. After gluing, I flatten one side with the CNC, then I flip it over to do the carving. My issue is that both the front and back edges have a tendency to curl up. I done several larger carvings, but this seems to come up regularly. On one of the photos I have marked what I’m referring to. Can someone please give me some suggestions on how to remedy this flaw? TIA
What is the moisture content when glued up? How long after the glue up do you flatten on the CNC? Glue ups should be allowed to stabilize for a period time commensurate with the moisture content. The glue itself actually adds moisture to the wood.
The thinner the stock seems to want to warp like you see above, the other issue is the design itself. You have a pocket’d square that’s is thicker and centered on the glue up that is keeping the stock more rigid and allows the edges to dry at a different rate than the center. Even alternating the pith orientation opposite to each other does not always guarantee tee for the stock to remain flat. In my experience the moisture is the overriding factor.
The best way i have found is to use end grain to remove as much cupping as possible.
I’m not sure what the moisture content is, I’ve had the wood for probably 3 years sitting in my basement wood shop. It was sitting for maybe 3 - 4 weeks after I glued up before I did any cutting on it. I have a couple of other thoughts on this, one is to cut my pieces 3 - 3 1/2” instead of the 2 1/2”. The second thought is to make sure that the ends of the glued-up pieces are going downward as it sits on the wasteboard. Just have to be more conscious of it. ![]()
Two tools which are essential to wood working. A posture meter and Relative Humidity (RH) gauge/ I like a pin less meter which reads about 3/4"-1" deep. A quality RH reader is $200-300 you cn get a digital inexpensive one they just aren’t that accurate. RH has a huge impact and what wood does. it can change quite drastically from day to day.
Roger, I get this problem when I cut too much off stock when cutting out a 3D piece. Never know which way it will cup.
I just put some like foam tape or soft wood strip under it and ease down on the edges with clamps. One can bend it back the other way in time. Just work with it, but be ready to put some finish or sealer on the back side to keep it from doing it again.
I’ve saved a lot of work by un-bending wood pieces. ![]()
What is your trick for “un-bending”?
Sorry I’m coming to this late.
tldr; for large complex shapes like I would use a surrogate spoilboard attached to the slats, etch outside profile into it, then make sure the material is secured very well all around the perimeter. Should minimize chance of edge issues but can’t be fully eliminated.
So I would speculate its a combination of workholding, thinning out the wood towards the edge, and the irregular shape of the toolpath for the outer shape.
Thinning 1.5" down to what looks like about .75" at the edges some movement is inevitable. I can’t tell what wood that is. Some woods move more or less than others.
With perfect full surface workholding, you might find when you remove it from the spoilboard, it still cups one way or the other.
If you can orient the grain vertically as you said, that should resist cupping movement more. All your pieces in that end grain photo are almost dead flatsawn grain running horizontally parallel to the surface. Flipping those end over end helps more with counteracting warping along the length of the grain but not cupping across the grain IME. I work with wide thin flatsawn bookmatched maple a lot. Its common for one side to cup up and the other side to cup down. I learned to expect this and leave a buffer to thickness sand flat twice until its laminated to a substrate.
The left side with the pull up outlined in red has a large area routed into the spoilboard underneath where it couldn’t possibly be held down. Even without that IMO this is the biggest limitation of the raised slats and extrusion table. There are always areas where the workpiece isn’t supported underneath.
This is where I break the rules and use a surfaced intermediate spoilboard on top of that for everything. First thing I do after attaching it is etch the outline of the project into it. Then I know the exact perimeter where the piece will be cutout to be sure there is tape or glue right up to the edge.
A shape like that which is highly irregular forces the cutter to make a lot of short quick jerky moves in the cutout toolpath. That’s added stress which increases the chances of compromising the workholding at the edge.
So again …could be several things adding up. Hope this helps.
PS I agree humidity is always a factor too. Good to have a few cheap gauges around to be aware of big day to say swings.
