so I’ve been making signs and such and using the basic Times new roman regular and for some reason when I go to add the tool paths it does like doing the lower case k idk why and its quite odd. idk if anyone else has had an experience like this before but idk how something like that would be fixed jc
and if I make a lower case k in the same way by itself it works
If you haven’t already, please update to the testing version: https://carbide3d.com/carbidecreate/unstable/ and see if that addresses things.
If it doesn’t, please send in such problem files to support@carbide3d.com with specific instructions on causing the problem and we’ll try to have a developer look into them.
